Adjusting the steering wheel
1995 OLDSMOBILE CIERA
44,700 MILES • 3.1L • 6 CYL • FWD • AUTOMATIC
JAYSINBAKO
  • 5 POSTS
The problem i have is that the steering wheel completely covers the two drivers side air vents preventing air from reaching the driver. With the 110° summers we have here I need all the air I can get. I am wondering if it is possible to remove and replace the steering wheel at a different angle? (so it looks like it's making a turn while driving straight). It does have airbags so I am not wanting to go after market steering wheel.
Jul 14, 2017 at 9:37 AM
STEVE W.
  • 15,113 POSTS
The steering wheel is in the position so the braces do not block the instruments. As you have an airbag you also cannot rotate it on the shaft, the clock-spring that connects the airbag and horn do not have room to allow that. Being a 1995 you may want to have the AC system tested, the charge may be low or the compressor getting weak, both will lower the ability of the system to cool the interior.
Jul 14, 2017 at 1:55 PM
JAYSINBAKO
  • 5 POSTS
Alright. That pretty much answers the question. The a.c. system is new it's just that the position of the wheel blocks the driver vents from contacting directly. Other than that it blows cold and hard.
Jul 16, 2017 at 8:27 AM
STEVE W.
  • 15,113 POSTS
Yeah, some days you really question the folks who design these things.....
Thanks for using 2CarPros come back anytime, tell your friends about us.
Jul 16, 2017 at 9:51 AM
