Dears, do you have some diagram schematic or text instruction of adjusting points for driver's side electric window?
I had an accident and maybe it is misaligned because of the crash.
Driver's door was damaged, and I went to repairman.
Now when closing to the top it goes a little bit down from the point 1, and when you pull it manually it goes to the top of point 1 (where the mirror holder ends) also to the top of point 3 (under the plastic trim of the roof), but not to the top of area 2 (about 3-4mm lower).
Thanks in advance
(The points image is from internet, the other is the door before reparation)
Thanks in advance
May 7, 2025 at 2:42 PM
