Problem adjusting tension on serpentine belt
1999 SATURN SL2
220,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
  • 5 POSTS
Can't remove auxiliary engine mounting brackets.
Dec 19, 2021 at 1:54 PM
  • 5 POSTS
I need access to the belt tension adjusting part.
Dec 19, 2021 at 2:02 PM
Good afternoon,
I attached the procedure for removing the tensioner and installing it for you below so you can gain access to the struts.
https://www.2carpros.com/articles/how-a-serpentine-belt-tensioner-works
Let me know if you have any other questions.
Dec 19, 2021 at 2:42 PM
  • 5 POSTS
I can't read the type.
Dec 19, 2021 at 3:17 PM
I don't understand. Please explain.
Dec 19, 2021 at 3:19 PM
  • 5 POSTS
Never mind. I was able to enlarge it to read text.
Thank you.
Dec 19, 2021 at 3:43 PM
Let me know if you have any questions.
Dec 19, 2021 at 4:10 PM
  • 5 POSTS
Well, I think lifting the engine was quite a bit more work than I intended to try to do. I sprayed some belt rejuvenator or conditioner or whatever that stuff is called on the belt and I'm hoping that'll hold for a while. Thanks for your help.
Dec 19, 2021 at 5:13 PM
That is very temporary. It will wear off very quickly.
Dec 20, 2021 at 5:10 AM
Did you respond? I got an email but nothing came through.
Dec 25, 2021 at 5:19 PM
