Adding driving/fog lights
2019 TOYOTA CAMRY
7,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
CLOSCLOS70
I have the car listed above (XSE), and the front light assembly consist of one cable hardness. I don't know which wire out of the 9 stranded wires are for the turn signal so I can tap into for the adding fog light and LED turn signal kit.
I do have the harness.
Clos
Sep 3, 2019 at 11:53 AM
I found the headlight and running light/blinker wiring for your car so you can see how the system works and which wire to tap into. this guide will help you test for power:
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Sep 4, 2019 at 6:46 PM
