Added small amount of transmission fluid to the engine
1998 BUICK LESABRE
170,000 MILES • 2.8L • V8 • 2WD • AUTOMATIC
BETS777
Yesterday I was topping off the oil and as I started to pour it looked a bit red. I stopped. I believe someone put transmission fluid in a bottle of that said oil. I would say I put in a 1/4 of a quart give or take. Likely less than that. I assume this will not cause any harm. Should I let it be or change it again?
May 12, 2022 at 4:24 PM
SQM
  • 6,383 POSTS
Adding transmission fluid in oil reduces the effectiveness and efficiency of the engine oil. With having just, a 1/4 of a quart it likely be okay.
However, I would recommend changing out the oil and filter to be on the safe side.
Let me know of any questions.
Thank you.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
May 12, 2022 at 5:29 PM
