2007 Acura TSX Loud noise going from park to reverse or fro
2007 ACURA TSX
23,000 MILES • 4 CYL • FWD • AUTOMATIC
TONYL
I have a 2007 Acura TSX with 23,000 miles on it and which was purchased new. I recently discovered a loud noise when shifting the car from park to drive and from park to reverse. The noise is most noticeable when the car is cold or when the car is in an enclosed space such as a parking garage or when the car is on an incline. I spoke to the Acura dealer service department about this, and they said this was "normal". Other than this noise, I haven't noticed any other problems.
Do you think this is normal?
Nov 20, 2008 at 7:47 PM
ZACKMAN
  • 4,202 POSTS
It is probably your trans control module shifting, which is OK. Just make sure that you have enough transmission fluid in the trans pan.
Dec 11, 2008 at 7:53 PM
BEZONIE
[quote:5180ae7950="tonyl"]Transmission problem
2007 Acura TSX 4 cyl Front Wheel Drive Automatic 23000 miles
Do you think this is normal?[/quote:5180ae7950] The same thing happen to me 5 months ago, I ask one of my friend and he say that I should put the parking brake on when I park the car, when you put your car into park do not take your feet off the brake peddle until you put the parking brake, and when you go to put it in reverse or drive put your foot on the brake peddle first then put the parking brake down then put in in drive or reverse. I been doing that ever since he told me and never heard that noise aging hope this help.
Apr 20, 2009 at 4:45 AM
