I've had a recurring clicking noise that happens when you apply the brakes or turn a corner slowly. One shop says it's the front disc pads that need to be replaced but I'm skeptical because there's still a lot of pad left.
A second shop says it's the front wheel bearing that needs to be replaced and I should take it to the Acura dealership because it should be covered under warranty.
Appreciate your thoughts and if you concur that it's a wheel bearing, what should that cost.
Thanks!
Thanks!
Jun 14, 2008 at 4:03 PM
