Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
Glove Box Housing Removal/Installation
SRS components are located in this area. Review the SRS component locations (see COMPONENT LOCATION INDEX ) and the precautions and procedures (see PRECAUTIONS AND PROCEDURES ) before doing repairs or service.
NOTE:Take care not to scratch the dashboard and related parts.
Remove the glove box (see GLOVE BOX REMOVAL/INSTALLATION ).
Remove the glove box housing (A).
Remove the bolts (B) and clips (C).
Release the clips (D) by gently pulling the bottom of the glove box housing out.
Disconnect the trunk lid opener main switch connector (E) and light bulb connector (F).
Fig. 6: Identifying Trunk Lid Opener Main Switch Connector And Light Bulb Connector With Torque Specifications
Courtesy of AMERICAN HONDA MOTOR CO., INC.
Replace the four clips along the top edge of the glove box housing.
Install the cover in the reverse order of removal, and make sure the connectors are plugged in properly.
Nov 30, 2008 at 7:05 AM
