Just received new cabin air filter
2008 ACURA TL
30,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRIQS
Just received new cabin air filter for my 2008 acura tls with instructions that do not match. Instructions indicate to remove the glove box and then some other screws to gain access. Not so easy. Removed the glovebox to get it out of the way and found only 2 screws. Removed the two screws and the back of the glove box does not come out. Suggestions?
Nov 28, 2008 at 3:45 PM
DAVE H
  • 13,384 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car. https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter Glove Box Housing Removal/Installation SRS components are located in this area. Review the SRS component locations (see COMPONENT LOCATION INDEX ) and the precautions and procedures (see PRECAUTIONS AND PROCEDURES ) before doing repairs or service. NOTE:Take care not to scratch the dashboard and related parts. Remove the glove box (see GLOVE BOX REMOVAL/INSTALLATION ). Remove the glove box housing (A). Remove the bolts (B) and clips (C). Release the clips (D) by gently pulling the bottom of the glove box housing out. Disconnect the trunk lid opener main switch connector (E) and light bulb connector (F). Fig. 6: Identifying Trunk Lid Opener Main Switch Connector And Light Bulb Connector With Torque Specifications Courtesy of AMERICAN HONDA MOTOR CO., INC. Replace the four clips along the top edge of the glove box housing. Install the cover in the reverse order of removal, and make sure the connectors are plugged in properly.
https://www.2carpros.com/forum/automotive_pictures/266999_house_1.png
Nov 30, 2008 at 7:05 AM
