Buy the filter.
Remove the screw highlighted in the front and find the back ones. Lift off cover and remove the old filter, reverse procedure to install.
Oct 30, 2010 at 8:37 AM
FORTE
MEMBER
1 POST
How do I access and replace the engine compartment air filter on my 2004 TL?
Jan 27, 2021 at 2:09 PM
(Merged)
SATURNTECH9
CERTIFIED EXPERT
Air Cleaner Element Replacement
NOTE: Do not use compressed air to clean the air cleaner element.
1. Open the air cleaner housing cover (A) and remove the clamps (B).
2. Remove the air cleaner (C) from the air cleaner housing (D).
3. Install the parts in the reverse order of removal.
There you go.
(Merged)
BTULSHI
MEMBER
1 POST
how to replace the engine air filter?
(Merged)
KHLOW2008
CERTIFIED EXPERT
Hi btulshi,
Here are the procedures.
AIR CLEANER REMOVAL/INSTALLATION
1.Remove the bolts (A) and clamps (B).
2.Remove the air cleaner (C).
3.Install the parts in the reverse order of removal.
(Merged)
ERIC JUSTIN STEVENSON
MEMBER
1 POST
Does the type s take the same air filter as the base?
Jan 27, 2021 at 2:10 PM
(Merged)
DANNY L
CERTIFIED EXPERT
Hello, I'm Danny
No, The TL base model and the Type S air filters are different. I've attached the pictures below with the part numbers from AutoZone parts stores. The Fram CA8475 is for a TL base model and Fram CA9502 is for a Type S. Hope this helps and thanks for using 2CarPros.
(Merged)
DANNY L
CERTIFIED EXPERT
Hello again.
Here is a tutorial showing how to replace an air filter.
