Replacing the module isn't too hard of a procedure. However, you will need to bleed the brake system when finished with the install.
To get you started, here is a link that shows the procedure in general. You can use this as a guide when doing the work.
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
IF you look at the attachments below, they include both the directions and pics specific to your vehicle for replacement. Starting with pic 4 are the bleeding procedures.
I hope this helps. Let me know if you have other questions.
See pics below.
Apr 1, 2021 at 8:48 PM
