2000 Acura TL transmission
2000 ACURA TL
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
DRRCKRIVERA
My transmission goes hard into gear as it shifts. while driving and initial shift
Jan 19, 2010 at 11:19 AM
MIRROCK
  • 22 POSTS
If these transimissions were anything like the 2001's 02 and 03's then the trans may be getting ready to go. Mine was doing the exact same thing so I check the fluid and found it to be low and a little burnt. I do not think you can just add fluid to these, has to be pumped in at the dealer. I would check with your dealer since these were so bad there was even a recall on them at one point. I know it applied to my 01, im not sure about the 2000's
Jan 21, 2010 at 4:40 PM
