2000 Acura TL braking
2000 ACURA TL
137,000 MILES • 6 CYL • FWD • AUTOMATIC
VANGAMBIA
when braking hard there is a very slight shudder in the weeel
Aug 19, 2008 at 2:13 PM
KHLOW2008
  • 41,814 POSTS
Hi vangambia,
If vehicle is equipped with ABS, it is normal to feel some vibrations when braking hard when the ABS kicks in.
Aug 20, 2008 at 8:34 AM
VANGAMBIA
Thank you very much. The car is indeed fitted with ABS
Aug 20, 2008 at 9:52 AM
MOOREV1
Your front rotors require machining or replacing. That will cure the pulsing.
Aug 23, 2008 at 12:33 PM
KHLOW2008
  • 41,814 POSTS
When rotors goes bad, pulsing is felt with light or normal braking effort, NOT when braking hard.
Aug 23, 2008 at 8:43 PM
