Code P1768
2000 ACURA TL
111,000 MILES • 6 CYL • FWD • AUTOMATIC
PHAZE915
diagnostic test showed this code p1768 manufacture control transmission. what does this mean? I've had so many problems with my trans I've spent over 5000$ and its still no good.. please help me..
Dec 11, 2008 at 8:07 PM
This code tells you that you have a circuit issue with the clutch pressure control solenoid valve A.
Basically, this could be a connector, circuit, or control module issue.
So, we need to run through the testing that I will attach below.
Here is a guide that will help with checking the voltage on these circuits:
Please see the testing below and let us know what you find on this.
Thanks
May 7, 2022 at 6:56 PM
