Transmission problem
1999 Acura TL Two Wheel Drive Automatic 140000 miles
This is a repeated issue. the trans oil is black. The transmission makes a noise when pushed to reverse, doesn't make any noise for others drive or neutral.
Heats up the engine fast and the local repair shop didn't want to change trans oil and asked me to check with a transmission shop. The trans shop said run the car with the noise and don't change the oil as the car might react badly.
what is the problem ? why is the trans heating the engine and turning the oil black. The oil was changed a year back when it was found black.
Any clues ?
Any clues ?
Mar 26, 2010 at 5:34 PM
