Acura 3.2 TL is idling high and low while in park and stopped at a traffic light. Runs fine while driving. What could the problem be?
Jan 1, 2008 at 9:38 PM
JEREMIAH
CERTIFIED EXPERT
probably an idle air control valve commonly called IAC valve.its common.no check engine light though?
Jan 6, 2008 at 1:24 AM
KELLY327
MEMBER
The check engine light did not come on. It only idles high and low sometimes because it hasn't done it since I sent the question in to you. Could a clogged fuel filter or trash in the throttle body cause this?
Thanks,
Kelly327
Jan 6, 2008 at 3:36 PM
JEREMIAH
CERTIFIED EXPERT
unlikely to be fuel filter or throttle coz its intermittent. could be a leak somewhere in the intake or throttle body.....but you said it's fine now. good luck
