1999 Acura TL feels like a miss
1999 ACURA TL
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
my acura started running rough one morning it feel like a miss. im so broke right now that i want to get it fix myself if possible
Jan 2, 2010 at 7:30 PM
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 2, 2010 at 8:50 PM
