how do I put code for radio to work again. I have the code
Dec 12, 2008 at 3:30 PM
KHLOW2008
CERTIFIED EXPERT
Hi ricktrev,
The preset station buttons are the numbers that you have to push according to the code sequence.
Note : If you had locked the radio by inputting the code wrogly more than 3 times, you need to reset it before you can inout new code. Remove back-up/radio fuse in undet hood fuse box or disconnect battery negative terminal for more than 10 seconds first.
