1997 Acura TL Rear Disc Brakes
1997 ACURA TL
RJGILBERT
Brakes problem
1997 Acura TL V6 Front Wheel Drive Automatic 116000 miles
I have a 1997 Acura TL3.2 and I need to replace the rear disc brakes. My question is how do I get the piston on the caliper to retract? I have loosened the cap on the master cylinder and tried to use a clamp to get the piston to retract, but it wouldn’t move. Is there some other way to get the piston to move inward?
Dec 6, 2007 at 10:10 AM
2CARPRO JACK
  • 11,533 POSTS
Screws in like a bolt.Put a little lube on the boot so it doesnt rip and turn the piston clockwise and it will screw intot the caliper
Dec 6, 2007 at 10:50 AM
Yep, here is a guide to show you how. You will need a special tool which you can get from the auto parts for for free if you rent it.
https://www.2carpros.com/articles/how-to-reset-rear-brake-calipers-with-parking-brakes
Jul 5, 2024 at 11:30 AM
