1996 Acura TL pass window
1996 ACURA TL
14,600 MILES • 4 CYL • 2WD • AUTOMATIC
JALENP
i use the control panel for my window my passenger window does not go roll down it moves a little then stop this happened on my maxima I replaced the driver side control panel and it fixed problem in past do you think that it will be the same for this car
Feb 24, 2009 at 10:30 AM
MPIRE73
  • 18 POSTS
I believe its the actual motor or actuator thats the problem. Mine passenger window does the same thing. Try to roll both windows up the same time, it actually slows the passenger window slightly, but noticeable. Alone it still is slow and creeps up.
Feb 27, 2009 at 10:51 AM
