1996 Acura TL Engines starts, but stops when starter stops
1996 ACURA TL
221,000 MILES • 6 CYL • FWD • AUTOMATIC
RCHAMP77
The engine will crank, and will run while the starter and the key is in the ignition position.
When i let the key go to the run position, the engine will die immediately.
It acts like the fuel filter is clogged or it stops getting electrical power.
Aug 16, 2008 at 10:59 AM
KHLOW2008
  • 41,814 POSTS
Hi rchamp77,
The ignition switch is bad and has to be replaced.
Aug 18, 2008 at 4:15 PM
RCHAMP77
yep, I replaced it and it worked fine.
Thanks,
Aug 18, 2008 at 11:06 PM
