1996 Acura TL Engine Oil Leak
1996 ACURA TL
175,000 MILES • 4 CYL • FWD • AUTOMATIC
SAMIRTHAKUR
I see engine oil leaking from my 1996 Acura 2.5 TL. I wish to know the reason for the same an the approximate cost involved. If possible I would want to know the service center (not Mcdaniels Acura) around Columbia SC
Feb 8, 2009 at 7:50 PM
F4I_GUY
  • 3,302 POSTS
Unforunately we can not find oil leaks over the internet, their are numerous possibilities as to what it could be. Some quick checks you can do yourself would be to see if the drain plug bolt is tight and the gasket is not leaking, also ensure the oil filter is good and tight.
Feb 17, 2009 at 5:53 PM
MPIRE73
  • 18 POSTS
You can actually take it any Honda shop. McDaniels is the only Acura dealer around the Columbia area, but i worked for Honda Cars of Columbia and the parts are cross-referenced and sometimes cheaper!
Feb 27, 2009 at 10:56 AM
