Hi joingary,
HEADLIGHT (LOW BEAM)
1. Disconnect the 3P connector (A) from the headlight.
2. Remove the rubber cover (B).
3. Pull the retaining spring (C) away from the bulb (D), then remove the bulb.
4. Install a new bulb in the reverse order of removal. Make sure the notches in the bulb align with the tabs in the headlight.
Mar 27, 2010 at 4:59 PM
