2005 Acura RSX Faulcode p0177
2005 ACURA RSX
75,000 MILES • 4 CYL • 2WD • MANUAL
ELLEN01
Check engine light on. Found faultcode p1077 and followed outlined check and procedure within Tech service bulletin 05-309...replacing imt (imrc) solenoid valve....light came back on....further diagnosed and replaced imrc rotary valve which goes under intake...still to no avail.....light still comes back on with same code.....?
Sep 21, 2009 at 4:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check the vacuum hose between the IMT actuator and the IMT solenoid valve. also inspect the other vacuum hoses that are connected to the system.
Sep 21, 2009 at 6:34 PM
