Engine Mechanical problem
2004 Acura RSX 4 cyl Two Wheel Drive Automatic
Can someone tell me if I need to reach the starter from below or the top.
The top seems the best option, but I need to remove the intake throttle body houseing off. If so, is there are gasket that I will need to replace.
The bottom seems impossible, but if that is they way then I need advice on how to reach the top bolt and wires. I seems to tight to reach from the bottom.
Thanks,
Jason
Thanks,
Jason
Apr 10, 2009 at 5:20 PM
