2004 Acura RSX Keyless entry
2004 ACURA RSX
64,000 MILES • 4 CYL • FWD • MANUAL
STAFSIAENS
2004 Acura RSX TYP S. MY two keyless entry fob's won't open or close the doors anymore. The system works fine using the keys or the master door lock switch. Replaced the batteries in the fob's and reprogrammed the transmitters, still not working. Fuse is OK. Does anybody have any idea how I can fix it?
To Dave H. As I said in the question I have already the programming procedure, reprogrammed the fob's and it does not work. I also already checked the the back-up fuse. So your response doesn't help me at all.
Feb 4, 2009 at 10:26 AM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated
Hope this helps .. let me know
Transmitter Programming
Storing transmitter codes
The codes of up to three transmitters can be stored into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE:It is important to maintain the time limits between the steps. Make sure the doors, the hood and the tailgate are closed.
Turn the ignition switch ON (II).
Within 1 to 4 sec., press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit built into the power window master switch.
Within 1 to 4 sec., turn the ignition switch OFF.
Within 1 to 4 sec., turn the ignition switch ON (II).
Within 4 sec., turn the ignition switch ON (II).
Confirm you can hear the sound of the door lock actuators within 1 to 4 sec., then push the transmitter lock or unlock button again, or the code will not be stored.
Within 10 sec., aim the transmitters (up to two additional ones) whose codes you want to store in the keyless receiver, and press the transmitter lock or unlock buttons.
Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
Turn the ignition switch OFF, and remove the key.
Confirm proper operation with the transmitters.
NOTE:Once the programming mode is entered, the remote button must be pressed a second time. If the button is not pressed, or if the ignition switch is turned OFF, the programming for all remote will be cancelled.
Feb 11, 2009 at 1:58 PM
STAFSIAENS
[quote:b4c8040318="Dave H"]Hello .. thanks for the donation .. much appreciated
NOTE:Once the programming mode is entered, the remote button must be pressed a second time. If the button is not pressed, or if the ignition switch is turned OFF, the programming for all remote will be cancelled.[/quote:b4c8040318]
Feb 12, 2009 at 8:17 AM
DAVE H
  • 13,384 POSTS
Sorry about that .. i added all the test but I mainly wanted you to see the last bit .. i should have made it clear !! NOTE:Once the programming mode is entered, the remote button must be pressed a second time. If the button is not pressed, or if the ignition switch is turned OFF, the programming for all remote will be cancelled. Transmitter Test NOTE:If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter. If any door or the hatch is open, you cannot lock the doors with the transmitter. If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch. Open the transmitter and check for water damage. If you find any water damage, replace the transmitter. If there is no water damage, go to step 3 . Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter. If the doors lock and unlock, the transmitter is OK. If the doors don't lock and unlock, go to step 3. Fig. 11: Replacing Transmitter Battery Courtesy of AMERICAN HONDA MOTOR CO., INC. Reprogram the transmitter, then try to lock and unlock the doors. If the doors lock and unlock, the transmitter is OK. If the doors don't lock and unlock, replace the transmitter. Keyless Receiver Unit Input Test Remove the audio unit (see AUDIO UNIT REMOVAL/INSTALLATION ). Disconnect the 5P connector (A) from the keyless receiver unit (B). Fig. 5: Disconnecting 5P Connector From Keyless Receiver Unit
https://www.2carpros.com/forum/automotive_pictures/266999_rsx2_1.jpg
Inspect the connector and socket terminals to be sure they are all making good contact. If the terminals are bent, loose or corroded, repair them as necessary, and recheck the system. If the terminals are OK, go to step 4. With the connector still disconnected, make these input tests at the connector. If any test indicates a problem, find and correct the cause, then recheck the system. If all the input tests prove OK, replace the keyless receiver unit.
https://www.2carpros.com/forum/automotive_pictures/266999_rsx_1.jpg
Feb 12, 2009 at 9:51 PM
STELLAF
  • 8 POSTS
I just want to know that on what parameter automatic locks are safe?
Stella
Mar 2, 2009 at 3:29 AM
DAVE H
  • 13,384 POSTS
your locks are perfectly safe ... I do not understand what you want to know ?
Mar 2, 2009 at 10:42 AM
