will not crank over
2004 ACURA RSX
185,000 MILES • 4 CYL • FWD • MANUAL
ARCANHEL01
Brand new battery. When I turn on car panel lights light up, no click sound. In the beginning it would turn on after second or third attempt but now it will not start. I can push start the car and runs fine but once I turn it off will not turn on again.
Oct 31, 2010 at 1:27 AM
KHLOW2008
  • 41,814 POSTS
This sounds like you have a bad starter but to confirm the issue use a test light to see if the small trigger wire is getting power when the key is turned if so the starter is bad. Here are two guides to help you see whats going on and how to change out the starter with diagrams below:
and
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
Oct 31, 2010 at 2:57 AM
DENTALFITCHIC
  • 0 POST
Thank you so much for this guide worked perfect. I am back on the road. :)
Aug 14, 2018 at 1:17 PM
MIKELJEREMY2
  • 4 POSTS
Car wouldn't start. Replaced the battery, then the starter. Still will not crank.
Aug 15, 2018 at 1:45 PM (Merged)
FIXITMR
  • 9,990 POSTS
check fuses?
Aug 15, 2018 at 1:46 PM (Merged)
FIXITMR
  • 9,990 POSTS
try it in neutral?
MIKELJEREMY2
  • 4 POSTS
I tried to start in park and neutral, would not start. Checked all the fuses, none were open.
FIXITMR
  • 9,990 POSTS
when/where did this happen?
