Thanks for taking my queston.
When I pull up my window switch so that the window will go all the way up without having to hold the switch, the window goes up about halfway then comes back down. If I hold the switch the window will go up with no problem. I also have a problem with the driver door lock which will not lock with the remote but all other locks will. I can't push it down either but I can lock it the old fashion way by putting the key into the door lock and turning. The window problem I've had for a while but the lock problem just started a couple of weeks ago. both problems are on the driver door. thanks for your help Sonny
Dec 30, 2009 at 9:19 AM
