2002 Acura RSX knock sensor
2002 ACURA RSX
99,300 MILES • 4 CYL • FWD • MANUAL
HALLSGTR
I have a 2002 acura rsx type s and I got a new clutch and when I got my car back I had the malfunction indicator lamp on, and didnt notice it until two weeks later, I took it to advance auto parts to see what it was and it came up saying it was a knock sensor problem i believe. I was wondering where i could get a knock sensor and is it something i can replace on my own, if so, what are the steps to do this.
Jan 31, 2009 at 5:11 PM
DOCFIXIT
  • 18,828 POSTS
Located on left side engine facing front. Near oil filter see if connector may have been pulled loose during repair.
Feb 11, 2009 at 10:46 AM
MSANCH56
I have the same condition too. I have the manual transmission rebuilt on an 04 Acura RSX Type S and a couple of days later, the OBD showed a P0325 code which says Knock Sensor malfunction. Since the code showed up, I experienced engine stalling; sometime the idle went low and stopped. I will try to replace if this knocks off the malfunction indicator light.
Sep 11, 2010 at 9:06 PM
