2004 Acura RL Wood Dash Trim Removal
2004 ACURA RL
120,000 MILES • 6 CYL • FWD • AUTOMATIC
LOUISCELLI
How do I remove the dash wood trim so that I can access the radio? My NAV system is acting up and I believe that the wiring harness has become loose behind the radio.
Apr 11, 2010 at 9:11 AM
KHLOW2008
  • 41,814 POSTS
Hi louiscelli,
Thank you for the donation.
The center console front cover is held by clips that are plugged in.
Gently pull out on edges of center console front cover.
Climate control unit, radio unit and display unit are mounted on brackets bolted to back side of center console front cover.
Remove as an assembly.
Remove bracket mounting screws from center console front cover.
Remove 6 screws securing display unit to brackets.
Remove display unit.
To install, reverse removal procedure.
Apr 11, 2010 at 2:52 PM
