HOW DO I REMOVE AND REPLACE THE AUTO DIMMING REAR VIEW MIRROR?
Apr 7, 2008 at 3:44 PM
2CARPRO JACK
CERTIFIED EXPERT
My software doesnt show that mirror. Look for a set screw that is holding it to the piece that is glued to the window.Then there is usually a plug for the electrical, but it may be under the edge of the headliner, be careful not to damage it
Apr 8, 2008 at 7:44 AM
JEREMIAH
CERTIFIED EXPERT
you have to remove the ceiling light.pop out the plastic covers and you will see the screws. the sunglass holder hides another two.disconnect the connector then remove the cover from the top base of the mirror and pull down gently.carefull when putting back many have replaced windshields for broken mirrors
