I have just had the front brakes repaired,new pads,turned rotors and rebuilt calipers. Now when I first start out the brakes are fine but after a few stops there is a thumo-thump-thump noise as i am stopping. with a little pressure on the brakes and slowing down between 0and 10mph. I had the brake shop check it and they also looked at the cv joints,whell bearings and re removed the brakes and checked trhem but could not find anything. I went through a housing projects and made several stops and the noise got worse but the next day when I went out the noise was not there until I did a few stops then it appeared again Any Ideas
BOB
BOB
Feb 1, 2010 at 1:01 PM
