My car runs but doesn't move
1999 ACURA RL
100,000 MILES • 6 CYL • FWD • AUTOMATIC
RICHARDP42
this morning when pulling away from a traffic light the car suddenly made a zing noise and rolled to a stop. it seems to have lost the connection between the transmission and differential. all gear work causing the zinging noise, like two gears rubbing against each other. it also makes a clicking noise when moved from reverse to park. when the transmission is in park with the engine running it makes no noise.
When one wheel is jacked up and turned by hand with the transmission in park there is a clicking noise from somewhere in the transmission / differential area.
Sep 11, 2008 at 8:29 PM
MHPAUTOS
  • 31,937 POSTS
HI there,
I feel that you have suffered a major failure with in the transmission and a total re build may be needed, i would get a transmission specialist to check &b report for you.
Mark (mhpautos)
Sep 12, 2008 at 4:46 AM
KHLOW2008
  • 41,814 POSTS
Check for dislodged or damaged CV joints/shafts first.
Sep 12, 2008 at 9:45 AM
