Here is a full fuse box diagram and a guide to show you how to test and replace them. The cigarette lighter has a relay under the hood. Here is some diagrams (BELOW)
and
1 - Not Used
2 - Not Used
3 - 7.5 Amp Rear Window Defogger Relay, Cooling Fan Relay
4 - 10 Amp Radio, ACC
5 - 20 Amp A/C Clutch, Heated Seat (Premium Package U.S. And All Canada)
6 - 20 Amp ECU (PCM)
7 - 10 Amp SRS
8 - 20 Amp Driver's Power Seat
9 - Not Used
10 - 10 Amp Daytime Running Lights (Canada)
11 - 20 Amp Driver's Power Seat
12 - 7.5 Amp Daytime Running Lights (Canada)
13 - 7.5 Amp Meter
14 - 7.5 Amp Starter Signal
15 - 7.5 Amp ACG
16 - 20 Amp Bose System
17 - 20 Amp Front Left Power Window
18 - 20 Amp Front Right Power Window
19 - 7.5 Amp Mirror
20 - 20 Amp ECU (Body)
21 - 20 Amp Rear Left Power Window
22 - 20 Amp Fuel Pump
23 - 10 Amp Windshield Washer, Moonroof
24 - 20 Amp Rear Right Power Window
25 - 30 Amp Ingition Coils
26 - Not Used
Please run some tests and get back to us so we can continue helping you.
May 16, 2017 at 3:13 PM
