Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Acura
RL
Fuel System
Fuel Pump
Replace/Remove
1997 Acura RL Fuel Pump
1997 ACURA RL
294,000 MILES • 6 CYL • 2WD • AUTOMATIC
JONTAVIUS
MEMBER
1 POST
FOLLOW
How do I check to see if the fuel pump is not working? If not, how do I install a replacement?
Apr 16, 2010 at 4:55 PM
CERTIFIED EXPERT
Do you hear the fuel pump come On when you turn key on? If not check fuse and fuel pump relay, If so check the fuel pressure if its within specs.
Apr 16, 2010 at 5:13 PM
