1996 Acura RL Cruise Control not working
1996 ACURA RL
10,213 MILES • 6 CYL • FWD • AUTOMATIC
CHUCKIE365
  • 6 POSTS
I have a 96 Acura RL and when i try setting the cruise control on the car, the green light does not come on and the car does not go into cruise control mode. Can someone please tell me if there is a fuse for the cruise control system or relay that controls power to it? Thanks!
Dec 5, 2009 at 5:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuse #20 (20-amp) in the under-dash fuse box
Dec 5, 2009 at 10:17 PM
CHUCKIE365
  • 6 POSTS
Just to be sure...you want me to check the ECU fuse right? What exactly is the ECU and what does it do with relation to cruise control...thanks!
[quote:9d270dd92c="bluelightnin6"]check fuse #20 (20-amp) in the under-dash fuse box[/quote:9d270dd92c]
Dec 5, 2009 at 11:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
fuse #20 has several different circuits on it...the cruise control circuitry goes to the fuse #20 as well as several other components. the individual components don't necessarilly have to interact with each other..
Dec 5, 2009 at 11:08 PM
CHUCKIE365
  • 6 POSTS
Ok appreciate the information, what other symptoms might i see if fuse 20 indeed was blown? Again thanks for the quick responses! Much appreciated.
[quote:9d3e7dc833="bluelightnin6"]fuse #20 has several different circuits on it...the cruise control circuitry goes to the fuse #20 as well as several other components. the individual components don't necessarilly have to interact with each other..[/quote:9d3e7dc833]
Dec 5, 2009 at 11:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely car wouldn't be able to start and turn signals will not work.
since this is the case, most likely a faulty fuse is not the culprit. check your brake lamps to ensure they are working. the CC and brakes use the same switch to work. if the CC doesn't work AND the brake lamps do not work, suspect faulty brake lamp switch. let me know what you find..
Dec 5, 2009 at 11:13 PM
CHUCKIE365
  • 6 POSTS
Just checked...brake lights working fine...one thing i forgot to mention, i pulled Fuse # 1 under the hood because of problems with my ABS...is it possible the problem is associated with that?
[quote:b5ff4a873b="bluelightnin6"]most likely car wouldn't be able to start and turn signals will not work.
since this is the case, most likely a faulty fuse is not the culprit. check your brake lamps to ensure they are working. the CC and brakes use the same switch to work. if the CC doesn't work AND the brake lamps do not work, suspect faulty brake lamp switch. let me know what you find..[/quote:b5ff4a873b]
Dec 5, 2009 at 11:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
did the CC stop working after you had trouble with the ABS? it can definitely interferre with the CC if the ABS has issues because the CC uses the brake system to operate.
Dec 5, 2009 at 11:22 PM
CHUCKIE365
  • 6 POSTS
You know i dont really know...the ABS started making these crazy noises and leaking fluids and the mechanic said it would be about $1000 to fix. To stop all the noises he pulled the #1 fuse...maybe thats why i have the CC problems now...i guess i might have to be without it....if theres anything else you can think of i'd appreciate it. If not no worries...and again thanks for giving me the time of day ;-)
[quote:1353783ba4="bluelightnin6"]did the CC stop working after you had trouble with the ABS? it can definitely interferre with the CC if the ABS has issues because the CC uses the brake system to operate.[/quote:1353783ba4]
Dec 5, 2009 at 11:25 PM
KHLOW2008
  • 41,814 POSTS
Reinstall the # 1 fuse to test. If the cruise control works now, you don't have to go any further.
Dec 5, 2009 at 11:35 PM
