Hi Allen,
Let me know if this works.
ENGINE OIL LIFE/MAINTENANCE MINDER - PROCEDURE 3
With Technology Package
1. Turn ignition switch to ON (II) position.
2. Press the SEL/RESET knob on steering wheel until engine oil life is displayed.
3. Press and hold SEL/RESET knob for about 10 seconds. The remaining engine oil life reset mode will be shown on multi-information display.
4. Select RESET by pressing INFO (up or down) button, then press the SEL/RESET button to reset the engine oil life display. The maintenance item code(s) will disappear, and engine oil life will reset to "100". To cancel the oil life reset mode, select CANCEL.
Without Technology Package
2. Press the Select/Reset knob repeatedly until engine oil life is displayed.
3. Press and hold Select/Reset knob for about 10 seconds. The engine oil life and maintenance item code(s) will blink.
4. Press Select/Reset knob for another 5 seconds. The maintenance item code(s) will disappear, and engine oil life will reset to "100".
© 2008 Mitchell Repair Information Co., LLC.
Apr 9, 2010 at 9:19 AM
