2004 Acura RDX check engine light and shaking
2004 ACURA RDX
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
PHUCCUNG
hi, my car check engine light appear a week earlier, nothing happen. yesterday the car shaking in the morning around ten minute, then after that no shake at all.after work, i started the car it repeats like that, shake for ten minute. the check engine code is po300, po301, po302, po303, po305, po306 please help me with this problem, thankyou
Apr 9, 2009 at 6:29 PM
Multiple Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Apr 9, 2009 at 6:37 PM
I need to know what have you done so far on the above mentioned probable causes. This the things that will caused multiple misfires.
Apr 14, 2009 at 3:29 PM
