While attempting to change transmission fluid on my MDX, I removed driver side front wheel and saw a 3/8 drive square hole drain plug looking straight in from that side. I asssumed this was the drain plug. I removed it but no oil started to drain out. The oil that I could see in there appeared to be red indicating tranny fluid. I immediately checked the dipstick and the oil was at a normal level. I have no problem with the transmission and was wondering what is going on. Is this not the drain plug?? If not where is it? Please help
Sep 7, 2009 at 5:10 AM
