2005 Acura MDX a/c cabin filter change
2005 ACURA MDX
30,750 MILES • 6 CYL • AWD • AUTOMATIC
ACURICK
I know there must be a simple method of changing the a/c cabin filter but I haven't discovered it , any suggestions or help anyone? Thanks
Feb 22, 2010 at 9:32 AM
JCGUERIN
  • 4 POSTS
2005 MDX - Dust and Pollen Filter Replacement
The dust and pollen filter should be replaced every 30,000 miles (48,000 km) or 24 months, whichever comes first. Replace the filter more often if the airflow is less than usual, of if the vehicle is driven in areas that have high concentrations of soot from industry or diesel powered vehicles.
Remove the glove box.
If necessary, cut the plastic cross brace in the glove box opening with diagonal cutters in the area shown, and discard it.
the marks are located inside the plastic trim(pre-cut),
Remove the bolts, the screws and the glove box frame.
Remove the filter lid (A) from the evaporator, then pull out the dust and pollen filter (B).
Install the filter in the reverse order of removal. Make sure that there is no air leaking out of the evaporator.
Install the glove box frame and glove box in the reverse order of removal.
Apr 18, 2010 at 6:39 PM
