2004 Acura MDX Starter slow to disengage
2004 ACURA MDX
85,000 MILES • 6 CYL • AWD • AUTOMATIC
CODOG2
when starting the car cold I noticed I would get a noise for 1 or 2 seconds that sounds like the starter was not disengaging quick enough
I assumed it was the starter and I replaced it with a rebuilt unit. Unfortunately the noise still persists (it may even be more frequent than before). Is it possible the replacement starter is bad too? Should I be looking at something else? I checked the battery and it seems fine (i even left a charger on it overnight -still made the noise the next morning)
any suggestions would be appreciated
Mar 14, 2009 at 12:52 PM
DOCFIXIT
  • 18,828 POSTS
Where the two seals that keep moisture out in good shape and clean? Did you check flywheel gear teeth condition?
Mar 17, 2009 at 8:09 AM
RBC163
Did you get this fixed and how? We have the same issue with our 2004MDX. Any guidance would be appreciated
Dec 31, 2009 at 7:19 AM
