Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Acura
MDX
Engine
Timing Belt
Replace/Remove
2003 Acura MDX timing belt replacement
2003 ACURA MDX
83,000 MILES • 6 CYL • AWD • AUTOMATIC
JIM R WOODS
MEMBER
1 POST
FOLLOW
What is recommended replacement schedule? Should the idler and water pump be repalced at the same time? How many shop hours does this job require?
Jan 4, 2009 at 12:07 PM
ZACKMAN
CERTIFIED EXPERT
You should replace the idler. Water pump does not run off the timing belt, so no.
Feb 22, 2009 at 12:17 PM
