2003 Acura MDX brake clicking
2003 ACURA MDX
101,000 MILES • 6 CYL • 4WD • AUTOMATIC
BACHMAN28
On my MDX when I push the brake I get a clicking noise coming from the gear shifter. It is one click when depressing brake, and one click releasing the brake. Dealer says its normal, but i dont think so and wanted to make sure. Thanks.
Sep 26, 2009 at 10:06 PM
KHLOW2008
  • 41,814 POSTS
Hi bachman28,
When gear shift is in Park position, that is normal.
The interlock solenoid is being activated when the brake is depressed.
Sep 29, 2009 at 1:54 PM
BACHMAN28
[quote:5d323a3f2e="KHLow2008"]Hi bachman28,
The interlock solenoid is being activated when the brake is depressed.[/quote:5d323a3f2e]
Well it started at about 90,000 miles, and it clicks in every gear except 1, 2, and 3.
Sep 30, 2009 at 4:06 PM
KHLOW2008
  • 41,814 POSTS
It should not happen that way. There must be some wiring fault with the Park Neutral Position switch or interlock wiring/system.
The interlock control unit is not being informed that the gear shift is already out of park.
Oct 1, 2009 at 9:33 AM
