2001 Acura MDX Engine stalls on the traffic lights or stop
2001 ACURA MDX
134,000 MILES • 6 CYL • 4WD • AUTOMATIC
SUNILJOON
When I halt at a stop sign or traffic light, and the car is in drive (D5/D4/R), the idle would drop down below 500 RPM and stall completely or run rough. In case I switch to the Parking or Neutral, the engine idle would jump to 750. For a smooth transition to drive D5/D4/R, I would have to press on the gas to avoid stalling (obviously this creates sudden push/jerk).
While the car will run smooth during warm-up, it would begin stalling out at traffic lights when it is about to reach up to normal / optimum operating temp.
Once the car will reach normal / optimum operating temp it will run perfect. It will idle at a smooth 750 RPM at every stop sign or traffic light.
No codes have been reported by the diagnostics (OBD).
Recent History –
• Transmission rebuild/fixed.
• Battery replaced.
May 9, 2010 at 11:17 PM
KHLOW2008
  • 41,814 POSTS
Hi suniljoon,
The idling system is not working correctly and I would suggest getting the throttle body and Idle Air Control valve cleaned and retest.
May 21, 2010 at 12:50 PM
