Oxygen Sensor Location
2001 ACURA MDX
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAVEGOYA
My car get scanned and they found a code PO135 and tell me to replace the oxygen sensor1 in bank 1. I bought the sensor and I want to do it my self. But I don't where is this sensor. I saw a few of this sensor in the motor. And I don't wich one I'm going to replace. If you can help me with a diagram. I can appreciate that. Thank you
Sep 1, 2008 at 4:25 PM
B1S1 is on the exhaust pipe upstream from the catalytic converter. The other is on the C/Converter. Here is a guide t help walk you through the repair and the location of the oxygens sensors in the diagrams below.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Sep 1, 2008 at 5:09 PM
KHLOW2008
  • 41,814 POSTS
Hi davegoya, It is the primary sensor.
https://www.2carpros.com/forum/automotive_pictures/192750_O2SensorAcuraMDX01_1.jpg
Sep 2, 2008 at 8:58 AM
HUNDRIVER
I have replaced the original oxygen sensors, Denso, with non-OE sensors, Bosch. I cannot clear the CE nor the VTM-4 lights. I also cannot engage the VTM-4 system. On computer analysis, the DTC still indicate the O2 sensors. As an electrical engineer, I am somewhat confident I installed them correctly. The MDX runs fine with no apparent problems. I am confused. Please help.
Apr 13, 2020 at 6:18 PM (Merged)
JEREMIAH
  • 217 POSTS
check to make sure that the correct sensors were installed in the right order. the primary is an air/fuel sensor and the secondary is the heated oxygen sensor.two different sensors that are not interchangeable.
HUNDRIVER
They both are 4-wire sensors. Two wires in each are listed as a heater circuit. I have rechecked the color codes and signal wires between the OEM and bosch wire color coding. I have cleared the VTM light but not the CEL. I'm now getting P0135, P0141 and P0133, indicating oxygen sensor heater circuit. The MDX still runs fine. I am perplexed.
