high mount break light dosen't work even replace a new blub.
Aug 28, 2010 at 12:11 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
are regular brake lights working? check fuses. if good than check for bad ground , should be behind left rear lining. brake light failure sensor (left side of cargo area) may also be bad if all else is tested good.
