a.c compressor not working
ACURA LEGEND
JAMMIE
i have a 93 acura legend 151000 mi. is there any way that i can have a p.c.m unit checked. and if the unit was bad is it possiable that it would not throw a code . its only effecting the compressor and it runs great. pressure switch is good unit comes on after i drive at a high speed.. any suggestion welcome. please help in hotlanta
Aug 21, 2007 at 5:58 PM
[quote:01812cc927="jammie"]i have a 93 acura legend 151000 mi. is there any way that i can have a p.c.m unit checked. and if the unit was bad is it possiable that it would not throw a code . its only effecting the compressor and it runs great. pressure switch is good unit comes on after i drive at a high speed.. any suggestion welcome. please help in hotlanta[/quote:01812cc927]
Do you have freon in the unit? No freon the PCM will not engage the compressor.
Get the low and high pressure check
Aug 21, 2007 at 7:02 PM
JAMMIE
yes, the car has freon when the compressor comes on it cools fine . im down to an electrical problem the pressure switch is new .
Aug 22, 2007 at 7:18 AM
