A/C and Heater Blower not working
ACURA LEGEND
MIKE ENANY
I own a 1991 Acura Legend LS Coupewith 201,000 miles.
Recently, the A/C and Heater blower quit working. Yesterday it worked for a short period of time and the A/C blew very cold air. Today, no blower speeds would operate, on either A/C or the Heater mode.
I hooked up gauges and , and sent some freon into the system. The gauges showed 45 lbs. pressure.
I drove the car and all seemed to work OK. Now, after the car sat for a few hours, again the blower motor will not work.
This seems to be an intermittent problem. Any suggestions?
Sep 3, 2007 at 10:59 PM
[quote:aa3b47469a="mike enany"]I own a 1991 Acura Legend LS Coupewith 201,000 miles.
This seems to be an intermittent problem. Any suggestions?[/quote:aa3b47469a]
Could be a loose connection on the control switch or at the resistor connector.
Sep 4, 2007 at 2:38 AM
MIKE ENANY
[quote:29f36f122f="rasmataz"][quote:29f36f122f="mike enany"]I own a 1991 Acura Legend LS Coupewith 201,000 miles.
This seems to be an intermittent problem. Any suggestions?[/quote:29f36f122f]
Could be a loose connection on the control switch or at the resistor connector.[/quote:29f36f122f]
Thanks for the quick response..Can you tell me where the resistor is located?
Sep 4, 2007 at 10:30 PM
1. Blower motor power transistor- located behind right side of dash -behind glove box.
2.Blower motor relay-its on the blower motor housing,next to AC and Heater blower motor.
Sep 5, 2007 at 1:43 AM
