1994 Acura Legend no heat
1994 ACURA LEGEND
172,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFFLOHSS00
engine warms up and tbere is no heat blowing in the car. i have replaced alot of thermostats and usually i follow the upper hose from the radiator to the thermostat housing. doesn't seem to be where i would usually find it. could you please describe where it is located. the car has sat and has not been driven much in the last 6 monthe. could it be a clogged radiator or something else. in the past no heat has ment a thermostat problem. thanks
Dec 7, 2009 at 4:39 PM
KHLOW2008
  • 41,814 POSTS
Hi jefflohss00,
Honda thermostats are installed at the lower radiator hose connection to engine.
Dec 8, 2009 at 6:59 AM
