1993 Acura Legend sluggish when accelerating
1993 ACURA LEGEND
261,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAHFLITE
i would to know what cause my car to move sluggish on the take off.
Jul 15, 2010 at 6:30 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 16, 2010 at 1:15 AM
